head together with new stem seals (Reinz) and valves lapped,
head on, timing pick up, flywheel after clean up, and new OEM clutch
gearbox bell housing cleaned up
engine bay clean as usual
vibration damper on, A/C compressor and bracket, friction wheel, box on, starter motor with purge and fuel pipe support bracket, rear lower mount and bracket, new OEM water pump, just waiting for new drive pulley, and inlet manifold on after wiring harness connected and fuel rail in.
coolant crossover pipe on and thermostat housing although the housing is going to get swapped for a new modified OEM one, I note it's the old type and a couple of ports are distorted on it too....
the support bracket on the head is a replacement, mentioned before, the bolt hole on the far left on the original was cracked all down the side
HPFP on, vacuum pump with new OEM seal, filter housing and oil cooler with new OEM seals, alternator, dipstick tube and stick in,
note the broken drill bit used as a tensioner lock, I didn't do this, the car was already partially disassembled, new tensioner coming today, also normally I don't interrupt the A/C but again, it was already done....
the drill bit I could leave as it doesn't affect the tensioner function, but it would probably affect me with future work so would be daft leaving it, seen a few now with the locking pins broken
the motor also has the lifters cleaned and installed, rockers cleaned and installed along with cams and is now timed, I just didn't take pics of that this time, engine oil is in too now
so just the exhaust manifold and turbo to fit after cleaning old oil from the shields and gasket, deciding if to reuse that or not, they usually go again alright but I have new if required, then make a decision on oil feed pipe and fit the rear shield and turbo support before adding the cat.
the modular assembly is a bit nicer on the R56's, one can basically build the whole thing out of the car bar adding coolant, all it needs after mounting is the main power cable bolting to the top support bracket, one point to the starter and the other to the alternator, better done as offering the motor into the bay really, the earth strap, then add the heater hoses, clip in the gear cables, and put the shafts in, plug in the ECU and it's in, bar fluids.
on this car whoever took it apart opted to remove the shafts completely which I don't do, it's not even necessary really to remove the front wheels on these, the lower ball joints separate by unbolting them from the lower arms,
note the cleaned up engine number face just above the wood block.
I have no doubts that I'll run into legacy issues with it, having never seen it run this stuff is a gamble, car bought blind so there could be anything going on really....
