121 - 140 of 163 Posts
Also what's the consensus on the diverters and hood scoops to provide more cold air to the IC. Looks to me like I should be removing the works diverter on my GP IC and letting the bonnet mounted part do it's work? Have I got that wrong?
From looking at previous topics the voltage and m7 good scoops are apparently quite effective. But it would be nice to see some solid data.
Is there any chance of a de-cat'd R53 passing the MOT emissions level with a good remap, or even without? I know a cat has to be in place for the test (unless you have a friendly tester)
you can log with torque if you use the add ons (basic logging with the paid version). you can even ghost the log over a a video as it records
No not really, the tritec is a bit heavy even with a cat..
Mine was seeing about 1.5 - 3º C above ambient at 24º C outside just now. But these results are off the boost.
I do run the coolest water setup though :p
Some great knowledge being shared in this thread, thanks guys! :)
