1 - 7 of 7 Posts
Bizarre one this and one i am keen to solve asap, as will become apparent as I write this.
So 2006 R53 facelift Cooper S with newer headlights with the little flap on the inside of the chrome surround on the headlight. This was something I de-chromed as part of the "Mini blackening". However, since I have done this, every time I press the left indicator stalk inwards to blast the windscreen and headlights the little existing chrome tops with their black overs fly off and leave me with the headlights looking like the extra little bit of headlight trim has been jettisoned somewhere.
This is especially irritating as the chrome part from MINI is a £11, the de-chrome blackout bit is £10 and the tip of the high pressure pump also seems to disappear every time the stalk operation is invoked. `They cost £54 each to replace.
So not keen on spending £75 every time I try to clean with windscreen and also not too bothered if this functionality ceased to be. So my questions are:
1) Is this a known thing after de-chroming?
2) How do I overide the headlight washers as I am not bothered about that functionality at all. The car is hardy driven and cleaned at all times so if I can just stick the chrome and -de-chrome black top back on, I m happy with that.
Thoughts anyone?
Thx
Scott
Works on pressure, iirc, so just unplug the pump in the passenger side wing.
You'll have to reconnect it for the mot though.
You can always pull the fuse to stop them operating, I did when the joiner on the pipe connected to the pump leaked and drained the tank. The pump would quickly fail if ever run dry. It is fuse 25 (30A) in the passenger inside fuse box.
They must work to pass the MOT (as commented above).
Only long term solution would be to fix them. You may have broken something when you dismantled them to paint them. They are quite delicate. Plenty of secondhand replacements available on eBay.
Fuck knows why I said to delve into the depths of the wing to get to the pump when there's an easily accessible fuse and/or relay to go at...
:ROFLMAO::sleep:
1 - 7 of 7 Posts
