21 - 29 of 29 Posts
I will cheers, gonna lay a tarp down and then pads/old towels on top. She'll be peeping through the blinds judgingly
Actually, for the other side, is a liberal spraying of WD-40 sufficient or is there something better?
Pretty much anything including dog p!ss is better than WD40.
One of the best is a 50/50 solution of atf/acetone which I keep in a trigger oil can for exactly times like that.
Alright, noddy question time...on the R56 do you unscrew the nut over the pipe (above the bracket) or the brake hose connector (under the bracket)?
nut over the pipe while holding the hose end
Thanks CoB, thought so. Mine is practically welded to the pipe and then snapped off. Bastard car.
21 - 29 of 29 Posts
