Hi all again, my troublesome Cooper S broke down with a fuel supply warning.
So on the side of the road checked every fuse I could then got towed back.
first of all I put a multimetre in the plug to the fuel pump which reported 9v while the engine is turning so I assumed fuel pump and replaced but still the pump is not working, In the bently manual it states to check F46 fuse in the footwell which is fine and remove the K36 fuel pump relay and bridge the pins to check the circuit, when I do that I hear a click under the dash but no fuel pump, the second hand pump came with the loom still connected but cut off so I stripped the wire back and connect a 12v battery an both pumps work and the car starts, bently states it could be the circuit to the pimp from the relay.
So my question is has anyone had this problem is it common and how to fix would be great...
regards
Lee.
regards
Lee.
