1 - 8 of 8 Posts
Morning all,
Sadly due to serious knee problems my car is now for sale:
210BHP
Hyper Blue
12 mths MOT
112k miles
3 Previous Owners - Owned since 2012
Recent work done includes:
  • Timing Chain Tensioner
  • Water Pump
  • 4 new Toyo R888R tyres
  • Brembo Front Brake Discs and Pads
  • AC Condensor, Drier and Compressor
  • Supercharger service with new gaskets
  • Oil and Filter change (Fuchs Titan GT1 Flex)
  • Gearbox Oil change (Fuchs Titan Sintofluid)
  • Brake fluid change (Motul RBF660)
  • Coolant change (Comma Xstream G48)
  • Front abs sensors and wheel hubs
  • Fuel Filter
  • Driveshaft boots
  • Pollen Filter
  • Alloy wheels refurbished
  • Sump, intake manifold, oil cooler, oil filter and rocker cover gaskets with crankshaft and timing sensor oil seals
Being a JCW model it features:
machined/ported head, larger injectors, reduced diameter supercharger pulley, JCW airbox, JCW stainless steel exhaust and larger front brakes.
It also came with the optional JCW sports suspension with lowering springs and JCW front strut brace. The suspension has been replaced with Koni FSD suspension using the same springs (regular springs are also included). The original JCW suspension is included in sale although one of the front struts seems to be leaking oil since being in storage but this could be repaired possibly?
Other upgrades include:
Alta 22mm rear anti roll bar (original also included)
4 additional Stainless steel headlamps
Interior wise, it comes with half-leather seats and twin dials with gauges in the centre for oil pressure, temperature and fuel. This is quite rare and a feature I sought out.
The history file verifies all the work done over the years, with most other notable replacements being:
Electric Steering Pump
Steering Rack and track rod ends
Clutch Slave cylinder and FTT Gearbox Bracket
Supercharger Belt tensioner damper
Rear Brake Discs and Pads
Rear Brake Pipes
Suspension StrutTop Mounts
Powerflex Front Wishbone Bushes
Front Lower Inner Mounts
Clutch @58k
Exhaust Manifold
Gear shift Cables
Basically anything that has needed doing has been done! The paintwork is in good condition for its age and has always been looked after - there are a few small stone chips on the front and small imperfections as you would expect for a car of this age. A great car that has been well maintained with a full service history (MINI, independents and self) and comes with a huge pile of invoices/receipts.
Also come with a set of Nokian winter tyres with good tread left and a box of various spares/oils/ filters etc.
I was intending to use the car as a hillclimb/track car (hence all the recent work done and track tyres) but knee problems mean that I just cannot drive the car comfortably now.
I'm looking for £4000 and am based near Hereford, close to the Welsh border. PM for more details.
This is typical..I bought my JCW a couple of weeks ago but this has a lot of stuff done to it that I'd like...
Looks like a corker mate.
1 - 8 of 8 Posts
