Forge Induction Kit for Cooper S (R56 N14 engine)
1373 Views 7 Replies 5 Participants Last post by  eliaevagora
Installed on my previous Cooper S and removed due to sale of car. Only c.500 miles covered before it was removed and is in excellent condition. The cone air filter is enclosed in a carbon fibre housing (can be removed) and is clean as a whistle.
All jubilee clips (3) will be supplied and hoses/tubes still intact.
Please note this will NOT fit on an R56 JCW as the engine layout differs to that of the Cooper S. I believe it is only compatible with N14 engines but this will need to be verified by Forge.
£130 ONO plus postage.
1 - 8 of 8 Posts
Only fits N14 engine, requires complete removal of airbox, can be fitted with a flat head screwdriver and a 20 torx screw driver. can be done in 10 mins. see my RIP build thread as I fitted one in my R56.
Good enclosed unit, doesn't suffer with any heat soak as away from turbo.
GLWS :)
Thanks for the additional info, I'm not so good with the technical stuff!
Hi is this still available if so would you take £110 posted?
you still got this
you still got this
Jordan, still got it. Pm'd you.
1 - 8 of 8 Posts
