1 - 10 of 10 Posts
For sale soon now .... is a nice smart 27,000 mile Cooper S R56 which is totally unaltered and has factory navigation, hill start assist, MFSW, unusual Redwood lounge leather seats and matching trim, gloss black trim, panoramic roof, black carpet. Web Design split rims, reverse parking sensors, auto lights, auto wipers, cruise control.
This is having the engine rebuilt due to chain jump, in fact at the moment I'm opting to make up another core motor and just use the original ancillaries and box, with a new clutch, rings, stem seals, ends, mains, cleaned, and run it as so.
It will get a new MOT.
This is a two keeper car, it has two working remote keys, one brand new I've just supplied, along with an original aerial,
Deposit secures. I doubt it will be available for long but posting here first.
I've swapped the rims for some from my black car which are in far better condition, previously refurbished in a sparkle finish some years ago now but a lot better than what was on here. You can have the originals if preferred but I'm not refurbing them. Or I have some Crown rims I can refurb for you.
Tyres on them are 595's in 215/45 but not much life in them, these will be swapped for 205/45 run-flats or order the tyres you want and send them here/bring them here, and I'll get them installed and balanced if preferred, or keep the 595's for a bit of fun and sort out the rest yourself.
There are some marks, it's still a 15 year old car, a couple of fine scratches here and there but minor, and a few dings also harder to see but one in particular in front of the left rear arch is easily visible yet dent man friendly should you wish to improve it.
Otherwise it is what it is, a genuine 27k vehicle, engine refreshed, very smart, maybe marmite looks but already nice comments.
A nice place to be ;O)
£5250
Reactions: Rusco_9 and BigMat
Discussion Starter · #2 ·
So this block is standard bore size of 77.00mm with No.4 re-sleeved to keep it this size,
New King standard size big ends and main bearings plus thrust washers, new main bolts, new front and rear main seals, new oil pump chain, new timing chain and guides
Reactions: Rusco_9
Head cleaned, valves cleaned, new stem seals, valves re-lapped, springs and caps cleaned, cam journals checked and cleaned etc.
Reactions: Rusco_9
Discussion Starter · #4 ·
Not putting all the detail up of this one, as usual it's manually cleaned, all went together well, it was built up and started after cranking with plugs out twice leaving the starter to time out in an effort to gain oil pressure and protect bearings, then with plugs in it fired right up quietly. Adaptions reset including Vanos I ran it for a minute during a brief leak check and coolant correction, then took a five minute clip right afterwards which is here if interested: R56S 2006 (56) Engine rebuild initial start - YouTube ;O)
Reactions: Fro-dizzle
Discussion Starter · #5 ·
Seats out for a better vac etc
Started to clean it a bit, won't be going mad, clay wiped and will just continue with a bit of polish
Nice this one, only one little dent to speak off that's noticeable, dent man job but I won't be doing it,
Gave it a run down the road a couple of times to clean the brakes a bit, needs MOT, and it wants some trim refitting after I cleaned the roof drains, but need to renew the roof motor before putting it all back, gave it a bit of a wipe around, looking a fair bit cleaner.
Discussion Starter · #6 ·
Some nicer pics, drives nice this,
open to sensible offers, very smart car for someone.... needs a new home
Reactions: Fat Controller
Discussion Starter · #9 ·
£5250 as said, it’s on eBay at £5500 obo
Still available although it’s out locally as a courtesy car for a week
Needs a home :O)
Reactions: Alan16ac
If you’re looking for an R56S, you won’t find better than one that’s seen TLC courtesy of Sean (CarsorBikes).
Still for sale? Price?
1 - 10 of 10 Posts
