1 - 5 of 5 Posts
As title,
This will soon be available,
Nice car,
Work detail will follow,
Price ~£8,000
More pics to follow, deposit secures ;O)
Discussion Starter · #2 ·
Spec on the car is:
Model series: MINI Coupé R58 / Sales description: Coop.S JCW / Body:Coupé Equipment specification:ECE / TYPE:SX52 / Transmission:SX52 / Steering:Right Production date:11.25.2011 / Paintwork: 850 / Upholstery: FKE1 Vehicle data
Designation Value
Doors 2
Engine N14
Displacement 1.6
Output (kW) 155
Drive FRONT
Ptwk. 850 pepper-white
Upholstery FKE1 Cloth/leather "Ray"/carbon-black
I level (ex works) R056-11-11-500
I level (current) R056-13-11-500
Individual equipment false
Filling quantities
Filling quantity for Replacement volume in litres Note
Coolant with AC 7.5 Manual transmission: lifetime oil filing
Coolant without AC 0 Manual transmission: lifetime oil filing
Rear axle 0 Manual transmission: lifetime oil filing
Engine (N14) 4.2 Manual transmission: lifetime oil filing
Transmission (GS6-53BG) 1.9 Manual transmission: lifetime oil filing
Brake 1 Manual transmission: lifetime oil filing
Equipment
Code Description
Series equipment
0210 Dynamic stability control
0255 Sports leather steering wheel
02P8 MINI LA wheel, Cross Spoke Challenge
03A1 JCW aerodynamic kit
0481 Sports seat
04AA Headlining anthracite
04AU Extended decorative scopes
04BD Interior surface Piano Black
04CU Interior colour, Carbon Black
04UF Sport button
0507 Park Distance Control (PDC), rear
0520 Fog lights
05AA Rear fog light
05DT Dynamic traction control
0736 2nd radio remote control key
0842 Cold-climate version
0853 Language version, English
Optional equipment
01CA Selection of COP-relevant vehicles
0230 Extra package, EU-speciifc
0249 Multifunction f steering wheel
0258 Tyres with runflat properties
02PA Locking wheel bolt
02RV MINI LA wheel in black
0302 Alarm system
0314 Door mirror, driver lock, heated
03A2 Black headlights
03A3 Roof and mirror caps, red
03A8 Sport Stripes, red
0423 Floor mats velours
0473 Armrest front
0493 Storage compartment package
04C1 Colour Line Carbon Black
0502 Headlight cleaning system
0522 Xenon Light
0534 Automatic air conditioning
0550 On-board computer
0563 Light package
05DA Passenger airbag deactivation
05DD Lifting jack
0620 Voice control
0654 DAB tuner
06FP Radio MINI Visual Boost
06NE Mobile-phone prep.,Bluetooth + USB/audio
06NF Music interface for Smartphone
06NM MINI Connected
06UM MINI navigation system
06VC Control, Combox
0785 White direction indicator lights
07L5 Wired
0812 National version England / Ireland
0872 Equipment "Chili"
0877 Omission of non-combined operation
0880 On-board literature, English
08S2 Coding, alarm signal
08SM Car ident. number visible from outside
08SP Control unit COP
08TG Thiefproofing device
Obviously the roof and mirrors have been changed to black and the JCW steering wheel added, otherwise not a bad spec imo.
Discussion Starter · #3 · (Edited)
at this juncture the car has three bald tyres, one burst, one almost on wear bars
the front pad sensor severed
no clutch operation - later finding the hard line corroded/disintegrating
a totally knackered AGM battery
zero fuel
a seized nsf locking bolt - later to shear the key
heavily corroded coolant return pipe from turbo to header/stat housing
all service items up including MOT
bit grubby
otherwise nice car.
Discussion Starter · #4 ·
at this point some temporary wheels and tyres (really very nice ones) have been installed for the MOT, mounting faces on the discs scotch brite cleaned and greased,
front and rear pad sensors renewed
engine bay initially cleaned and under bonnet
new AGM battery installed and registered
all fault codes scanned, report saved, cleared, adaptions reset (not Vanos at this stage), no faults returned,
in car settings reset, old Bluetooth devices deleted, personalised settings etc.
car interior initially cleaned
car exterior initially washed and clay wiped
Discussion Starter · #5 ·
tomorrow am I'll be at BMW collecting the turbo coolant return line
a clutch hard line
a new remote key and blade, the other is ok but I like to supply two for you,
a Pepper White touch in stick
the MOT is booked for tomorrow pm so will see how I get on, if I get the gears back the first step is go and get some super unleaded in it,
when I change the coolant return pipe (which is not leaking, just heavily corroded) I will flush the coolant and refill with OEM blue coolant I always use
I will also change the engine oil and filter regardless of whether done recently, I note the engine below the filler cap is remarkably clean compared to most I see
more to follow
the car is £8,000 ovno
deposit secures
1 - 5 of 5 Posts
