21 - 29 of 29 Posts
Chop it
no, forget the peddle, its all about the connection to the throttle its self. Are you use it is ticking, the only item which should tick is the ABS motor. The throttle can make all sounds but should not come to life till the engine is started.
Discussion Starter #22
Well I've swapped my throttle body over with Caffers, both throttle body's worked in his car so that's not the fault!
Discussion Starter #24
A fucking fuse, a bloody 5amp fuse F41 for parking sensors that I've never bloody had.
Discussion Starter #27
Only thing I can think of was a dropped a spanner an made a connection with the alternator, other than that I have no idea!
he says above, F41 5A fuse for parking sensors
21 - 29 of 29 Posts
