1 - 20 of 38 Posts
Hello all,
Having bought my R53 'S' (finally), fitted my new 17" Rota Grids and tyres I am looking where to go next.
Basically I intend to have a fast road / track day car build which will span my pay packets over the next few months.
I am no stranger to form > function with my last car being around 15mm off the floor. BUT this time its all about the performance. I intend to build the car properly and will be buying once and once only on each part.
I am new to the engine tuning world and my mechanical skills so far extend to assembling brakes and calipers, fitting coilovers and fitting exhausts. I will require masses of help along the way but I am sure you will all be here to lend a hand and take the piss when things go wrong.
Where should I start?
Do I stick with what I know to start with and use the car efficeiently to start with, a decent set of adjustable coilovers and brakes for example?
Which parts do I then start with, do I start with Exhaust, Induction, Intercooler, Remap in this order?
Your help is much appreciated and I look forward ot seeing you all around the forum and at various events in the future. :thumbup:
argumentum vel STFU
Corners - Plenty of coilovers to choose from, depending on what you're after and the size of your wallet. Get it set up properly.
Brakes - R56S front calipers and discs with Carbotech pads of your choice.
Power - 15-17% supercharger pulley, Dave.F induction, GP Intercooler should see you making some power to start with. For more, how big's your wallet? :)
It's up to you where you start.
A Supercharger doesn't change what I have already learnt then. To start with I should look at my handling and stopping. I mean I have fitted Toyo T1Rs for my road use at the moment and to be honest they are performing better than I thought they would so i can look at Coilovers next.
What sort of ranges do I need to investigate for Coilovers? In the past I have spent £250 and then spent £850 so I know first hand that I get what I pay for and I am going to ride at stock height until I can invest properly. Any names I should look at?
For a track car I would go:
Meister R coilovers - unbeatable track performance for the money
Full pollybush
R56 S brakes
Rear Anti Roll bar - Whiteline is what I'm going for
Drop links - again Whiteline
Rear control arms
Proper Geo setup
Then worry about power!
I was under the impression (according to their website) that Meister R Coilovers were specified by the company for track use only and were not road legal, this is obviously not the case?
Id suggest if you want to make it an out an out track car nothing less than ^^
KW V3 or Clubsports
Kavs rear Control Arms
Hotchkis RARB
Full set up by someone like Tony Franks / Lohen / Coastal..
And then move onto brakes..
If your budget allows of course go for clubsports/v3's or JRZ's but if not Meister R's do a bastard good job as long as your not looking for huge lows or the last word in comfort!
Jap Scrap
I'm not going to say anything regarding the Meisters incase Batou is still a little sandy... They are specified for off-road use only, but thats just to cover themselves. They are 100% road legal, as long as you've told your insurance company they are on.
First performance mod should be a Dave.f induction kit, best bang for buck imo. Dave is a trader on here and makes them in batches, if I'm not mistaken, he's doing some currently?
Flame grilled?
Cuntousaurus
I don't really work with budget too much due to mistakes buying cheap in the past, but in an ideal world I guess around 950 / 1000 max.
KW V2 (adjustable rebound damping) ~ £950 (V3 are about £1500 but also give you compression damping)
Copy of SPC Camber plates ~ £150
Copy of SPC Rear control arms ~ £130
Hotchkis 25mm "Chuck norris" rear anti roll bar. ~ £250 (?)
Whiteline/Powergrid rear drop links ~£150 (?)
Kavs Roll Centre Adjuster/Spacers ~ £70 (?)
Ignore Martin, he still thinks a budget/mid damper with camber plates performs better than a KW/Bilstein damper :laugh:
If your budget was £700 max I'd say Meister R, but stretching to the above will give you all you'll ever need in terms of suspension. You don't have to do all at once.
Discussion Starter #16
Okay so I need to take all advice on board for Coilovers and start to look at a set of R56 Cooper S stoppers.
Can't wait to get back on my feet (literally - im stuck at home on the sofa resting a severely sprained ankle)
Want to get back to the 'S' as I haven't driven since Saturday now.
no such thing in the UK, theres only a few performance parts that arent road legal technically a lot of brake pads actually as they are too good, theres a certain % friction under EU regs that they cant exceeded from stock %, de cats from cars with a factory supplied cat from 1992 ish, and racing harnesses that arent E approved although ive never seen the harnsess one enforced)
Discussion Starter #18
Do you run them by any chance :p
nope, ive tested most coilovers on the market for the mini, and sold most brands too, my default road choice are KW V2's + SPC camber plates, its a very hard set up to find any faults in
Discussion Starter #20
I have to say, KW variant 2 seem to be priced well, allow enough adjustment and I have run them once before on a previous car so can speak for quality.
Can I ask a noob question and ask if the camber plates are for fitment or if they are being used for performance gain?
1 - 20 of 38 Posts
