1 - 20 of 92 Posts
Administrator
To kick off a series of MT run product tests, we're starting with something nice and simple... a Dimple!
So firstly some background on the Dimple...
Magnetic oil drain plugs have always been one of the best ways to trap and remove microscopic metal particles from an engines lubricating oil almost since the combustion engine was conceived.
Sadly, these systems have been dropped in more recent years due to the relatively high manufacturing cost of magnets powerful enough to do the job we need them to do. This led to a sudden influx of cheap , alloy magnetic oil drain plugs from the far east and sadly, small, cheap, magnets simply will not do the job, regardless of what our competition would have you believe. In fact, they could shorten your engines life! (See technical section for more details on why this is...)
Why would I need a magnet in my oil you may ask...
To answer this properly I must share some facts with you.
Every time you run your engine, it becomes more and more contaminated with many thousands of tiny nano particles of harmful ferrous metal. These metal particles are so small that they cannot be seen by the human eye. They are mainly caused by friction and lots of it. For example an engine travelling at merely 2000 rpm sends the pistons up and down 33 times per second. Astounding really!
The human eye can only see a particle 40 microns or larger. The oil filter can only realistically filter out particles larger than 35 microns. The particles we are looking to catch with powerful oil filter magnets are about 35 microns or less in diameter, the smaller the particles the more harmful to the engine or transmission because they travel everywhere under hydraulic pressure, (oil pressure), and act exactly like a fine lapping compound, continuously polishing down all surfaces.
Let’s understand how big these particles are!
A fine grain of salt is 100 microns, white blood cells 28 microns, red blood cells 8 microns and bacteria cocci 2 microns. The only way to remove these damaging metal particles is with very strong magnetism!
The best time to use magnetic oil drain plugs and oil filter magnets is from new. When a new engine is fired for the first time it quickly starts to wash itself down internally with oil, so all the left over minute particles of ferrous material from machining, from bores, from piston rings and many other tight moving parts all gets washed around the engine and they all go through the sump at some time and remember, the oil goes through the oil pump before even the oil filter, so that is always unprotected. Grab that metal before it can leave the sump and cause premature wear!
The Dimple™ super drain plugs are the strongest high temperature magnetised drain plugs available, period. These magnets are the cure for your diseased engine and transmission oils because you can now effectively remove those tiny particles of metal in your oil so you can have peace of mind that your engine will last longer, maybe a lot longer. This is great peace of mind and in the long run cant fail to save your money as well.
Text courtesy of magneticoildrainplugs.co.uk
So now you know a little bit about what the Dimple does, let's see a simple demonstration of it working it's magic:
Now when we heard about the Dimple we thought 'What a simple idea!' and knew immediately we had to test it.
So we will shortly be completing oil changes on the MT Time Attack MINI and the MT Road Car and installing the the Dimple so we can monitor its effectiveness of catching microscopic metal particles and also compare the difference between the level of particles found in a track car and road car.
Each time the Dimple is removed, we will photograph what we find and post it here along with details on the oil used, amount of miles covered and car useage over that time.
Hopefully each time we remove the drain plug we will be greeted with a picture like this and the swapping from a standard MINI drain plug to a Dimplewill have been well worthwhile.
If you would like to test the Dimpleyourself then you can purchase them from here:
http://shop.motorsport-developments.co.uk/engine-products-221-c.asp
... for £19.99 including VAT and postage (UK mainland)
Or for more technical information on the the Dimpleplease go here:
Magnetic Oil Drain Plugs? - Technical Information On Our Magnetic Sump Drain Plugs
In the name of Fun
Always a great thing to have IMHO if they are quality ones so it's getting ordered as 20 quid for knowing I'm helping longevity is better than a few pints !
shame they don't list the gearbox one for R53 too as that's where I really want it
Administrator
They do one for both, just give them a call mate
just bought mine, cooper is due an oil change since its been layed up for a while, will report back in 6k time
Just for reference, the drain plug pictured is mine.
Magnetic Drain Plug was installed in April 2009 with approx 38K miles. Oil was changed and picture taken in July after about 4K miles. Oil brand is Royal Purple if anyone cares. Next change will be on Jan 30, again at ~4K miles. Will try to remember to post a pic.
Also using these in transmission.
Administrator
So as you can see, even with just 4k miles it's picked up a fair bit already :thumbup1:
I cheapo'd out as I put the engine back together when everywhere was shut
i used a neodymium magnet the size of a AAA battery on the outside of the sump plug and when I come to change the oil i'll post up the results
In the name of Fun
just ordered the same for my gearbox too
PowerRanger Reborn
These two clowns haven't got a clue, cant wait for this shed being built....it will have a cooper clutch plate, a manifold without a flexi joint, spark plugs over tightened and forget the matt black wrap, 2010 is all about a fully flocked wrap......PLEASE ::getcoat::
OJM was referencing SMCO magnets (Samarium Cobalt) which is rated at higher temperatures than our Dimple® super magnetic drain plugs. However, SMCO magnets are extremely brittle and would not even be considered for use in an automobile race engine. SMCO magnets are very weak in comparison to what Dimple® product "Black Hole"™ magnets are. SMCO is = to N30SH grade Neodymium magnets. Our magnets are the new N45SH High temp Neodymium magnets, which just recently became manufacturable to us. There is no stronger High temp Neodymium magnet on the market today. I disagree with the clumping theory discussed. If the test was done with an N45SH magnet there would be no overloading, heck, you could relax and go for a whole year without wiping off the magnet, You simply do not overload our Black Hole magnets. I guess all magnetic drain plugs are not created equal and one should examine and see how powerful a Dimple® drain plug is to fully understand it's potential to rid your oil of contaminants.
A Very Happy New Year to all MiniTorque members.
In the name of Fun
I'll be happily fitting both of mine
i suggest the blue-peter paper clip test to those worried about overloading
you may find that not all clips need to be connected to the magnet :tongue_smilie:
and can anyone remember trying to clean a simple low power magnet covered with iron filings
Dont make me pimp slap u
I can understand how a cheap magnets and really long times between oil changes could be dangerous. If the particles did build up and the cheap magnet couldnt hold it. There is a higher chance of it damaging the engine. Wouldnt you agree Mr Dipple. But as you said your product is superior.
Pay peanuts and get monkeys. Its amazing how some people go cheap and buy crap for theres cars instead of getting the better product like Mr Dipples products.
Experience vs Money!
We have been using a magnet plug for ever on my racing engines!! It also helps when you suck up a few Chevys!! makes it easy to locate them and remove them!! The idea is sound and been being used for years!! good product!!
Just me..........................
Thumper
1 - 20 of 92 Posts
