1 - 3 of 3 Posts
I have just fitted a JCW turbo to my N14 Cooper s, it seems to be dumpling boost when I go WOT. I'm sure I've read somewhere that I will need to fit a JCW map sensor but I can't find any posts again to confirm that. Dose any one have any experience with this? It has a Manic stage 1 map and is running fine when I put it back to standard. Also it is the older n14 without a MAF sensor and it has everything on it for a stage 2 if that makes any difference. Thanks.
Would also like an answer to this, also have a N14 cooper s with a JCW turbo, bit I run a stage 2 manic map, running a or b about 23 psi , is ok but soon as I run c, about 24 psi I think. any hard driving drops into safe mode cos of overboost. Would the JCW 3bar sensors let me boost past the 1.5 bar boost limit from the standard 2.5bar sensor.
Cheers
Sent from my Pixel 3a XL using Tapatalk
Dervtech mentioned the following when I asked after seeing it mention on one of their tunes on Facebook
You will need a JCW MAP and TMAP sensor to ensure accurate boost control
1 - 3 of 3 Posts
