1 - 3 of 3 Posts
Clubman Xenon and retrofits possible ?
HI all , new to the forum but wanted some advise and guidance as to if links on the site are available to diy retro fit the following for a non LCI 57 plate Dooper, nice base car but needs a little help now ….
1/Xenons, already have on route the complete lights washers ballasts etc etc plus about 8 -9 inches of the loom from the xenon car to convert the factory halogens..... hopefully a guide on this on here ?
Interested in OEM Sat Nav retro fit and climate panel, car currently has Air con but without climate
Already had my friendly German car specialists code out the light check so hopefully that's the only coding needed ? Understand the xenons have the wires switched round in the connector that goes into the headlight itself to enable the Xenons to fire up hence thought if I can get hold of part of the loom I maybe able to splice this into the factory halogen loom ? optimistic I know but ……
also looking for good guides on removing a door and stripping it down to a shell as I have to switch the drivers door over and have a bare shell that needs going onto the car and building back up
and lastly rear bumper removal process
any help advise or pointing in the general direction would be really apprieciated
cheers Mark
Hi,
xenons - yes you can retrofit but require coding IIRC
Factory nav - Don't bother, the sound system is wank anyway, get yourself a carplay system and some new speakers.
Everything else - Don't know I'm afraid
Is there a decent guide to retrofit ?
:crying:
Hi,
Ta for info ... is there a decent guide on this available ? Seems very year dependant on the approach you take
Cheees mark
Good to know !
1 - 3 of 3 Posts
