1 - 20 of 42 Posts
Here's what's left...
Collection from Mersea, Essex or postage agreed.
£1200 KW Clubsports + KW adjustable top mounts (r56 rear arm versions with the washer insert attached)
£500 R56 alloy trailing arms + R56 rear brakes (modded for r53 handbrake cables) & HEL lines (includes discs/pads), all bolts can be included.
£200 all four Hardrace upper & lower RCAs
£675 AP 304mm BBK, HEL lines, Carbotech XP8 pads and Nitrac discs
£100 Hotchkiss 25mm RARB
£475 Competiton Clutch stage 4 clutch + Competiton Clutch lightened flywheel
£850 Quaife LSD in facelift box
£675 16x7 Speedline Turini's + AD08R's, good condition wheels + good tread
£50 Stud conversion
£375 Vibratechnics upper, lower and gearbox engine mounts
£325 Cobra XL bucket seats on sliders in blue
£100 Innovate ATX oil temp and pressure gauge with sensors and a tapless adapter for the pressure sensor.
£175 Aero skirts black (damaged)
£175 Boot with Cooper aero spoiler, removed complete including glass, paint: Black 2 / Jet Black, code 668
£225 Bonnet, paint: Black 2 / Jet Black, code 668
£125 OEM steering wheel, three spoke, multi function. MFSW, with airbag
£125 (each) Doors, including glass, speakers, latches, can include interior panel, paint: Black 2 / Jet Black, code 668
£100 Standard head
£25 OEM Piston & con-rod
£50 Standard block, no pistons, includes crankshaft
Turbo kit is an Owen Development Garrett GTX 2863R, doesn't get much better than OD.
Turbo oil filter inline to turbo feed.
The cooling system is all custom by Forge Motorsport, custom rad, intercooler and oil cooler.
Large custom barrel inlet, electric water pump.
Grams wideband sensor and gauge
Custom exhaust 3 inch.
1000cc injectors
Specialist Components ECU with switchable maps (includes cabin switches)
HKS SQV4 BOV running recirculating, I find it holds boost much smoother recirculated
Tapped sump for oil return can be included
Was previously run at 350hp
Turbo kit £4750
I will have the block Shaun
Is the sump cheap, I can use one if my spare gets damaged getting the seized plug out,
tempted with the Innovate but it's been replaced now by another version, open to a revised price?
any damage on the door cards? £
any paint damage at all on o/s door? At all?
Thanks ;O)
is that a cooper spoiler? £
Comes with the sump. I'll have just taken the pistons out, all else will be there.
That very much is a revised price
The door cards are a 7/10
Door will likely need mopping. I'll double check for you.
Thanks ;O)
Sent from my Pixel 2 using Tapatalk
ok, ta
revised bit was referring to innovate
Must be my old Turini mate! Damn...wish I had the cash at the moment would buy them back in an instant. Some nice stuff on that list for sure GLWS!
That's the ones. Kept in the same quality condition
1 - 20 of 42 Posts
