So today’s the day when I finally get round to fitting my R56 brakes. All was going swimmingly until I tried to install the first caliper - it won’t fit over the pads! The piston is as far back as I can get it - can’t see that it could go back more.
The discs are brand new Nitracs and measure 22.1 mm thick. The pads are Ferodo DS2500 - each 17.9 mm thick including the 5.1 mm backing. The calipers are brand but were blasted and painted by a brake specialist who shall remain nameless and then stickered and clearcoated by me.
What’s the next step? Do I have bad pads or discs? Is sanding the friction material on the pads down a bad idea? As it stands, I can’t even get the claws and piston of the caliper over the edge of the pad, let alone the little bump in the middle of the backing! By my reckoning, I need at least 2mm more clearance.
All help appreciated!
