Bosch 650cc injectors
621 Views 10 Replies 3 Participants Last post by  DoubleP
Hello
One summer ~5000km drived bosch 650cc injectors for sale
Those are uscar type and adapters to EV6 are included in this
Price 125€ + postage
1 - 11 of 11 Posts
Semi interesting factoid. I have these on my car and at 4 bar base pressure they are spray around 730cc/min, which should be good for 400 crank hp @80% duty cycle
I go lean with these after 6000rpm. But I run my mini with e85, so that might be the reason. Have to pump about 30% more fluid than with normal 98octane petrol.
If new 850cc will not solve my problem, have to insert more powerfull walbro e85 capable fuel pump
Are you running these in the stock rail with the stock in tank setup? How much boost @ 6k?
Yes with stock rail, tank and 2 year old OM fuel pump. Boost is like little under 19psi 6k.
Lähetetty minun F8331 laitteesta Tapatalkilla
Gotcha. Your problem isnt the injectors or the pump, it's the fuel transfer regulator on the filter bucket in the tank. I had exactly this problem. You can add much bigger injectors and map for the drop in differential fuel pressure, but the correct way is to abandon the 'dead head' stock fuel system in favour of a return line setup
Yes, still in my stash.
120 and those have a new owner
These are still after new owner
Bumb. Spring sale. 100€ or place a bid
These are now sold
1 - 11 of 11 Posts
