1 - 5 of 5 Posts
Need a new one and they are very cheap second hand. Pan roof not working, radio showing as disabled so apparently common for these units to be faulty
once i have bought one, do i need to have it specifically coded? Also, any easier fixes?
Have changed the motor on the roof twice, works for a min and then dies. Also was suggested that the Ibus wire on the radio may be broken, it is not
If you let us know where you are, someone will likely know somewhere near you.
I would have thought somewhere with the facility to remanufacture an ECU would have the gear to code it to the car.
Discussion Starter · #5 ·
West London/Bucks - it was a swap service, they take your old one and send you a remanufactured one. Everything works fine until you switch the car off and leave it for 15/20 mins. Then the roof stops working again, i'm thinking that the body control module needs some sort of coding.
Any help appreciated as no one seems to know what is going on with it
1 - 5 of 5 Posts
