All new parts boxed, old parts bagged and tagged awaiting the start of the rebuild at at Technosport in Brent Cross.
The head is off for a clean up, minimal skim just to freshen the surface ,a 3 angle valve job and the block is to be cleaned, decked, bored and honed before the new parts get fitted. I've asked for pics along the way so will update as and when I get any.
Engine spec will be:
Forged Piston 10:1 Superetech 77.5mm
Supertech Piston Ring Set 77.5mm
Mahle Motorsport Big End Bearing Set
Mahl Motorsport Main Bearing Set
ARP Headstud Kit
ARP Main stud kit
Supertech Inconel Exhaust Valves
Supertech Titanium Valve retainers
Supertech Intake Valve guides Bronze
Supertech Collets
Supertech Headgasket
Ajusa Headgasket set
- -Minus Stock headgasket
Mini Inlet Cam Bolt
Mini Exhaust Cam bolt
Millers 5ltr Running in oil
Ajusa Sump Plug washer
Supertech Forged Conrods
Beehive Valve Spring Kit
Quaife LSD
Tinken Diff Bearing
Mini Gen 2 Guide Washer
