1 - 20 of 849 Posts
· Premium Member
Current Spec
KW Clubsports + KW adjustable top mounts
Hardrace upper & lower RCAs
KnD upper and lower RCAs (not fitted)
R56 alloy trailing arms + R56 rear brakes & HEL lines
AP 304mm BBK, HEL lines, Carbotech XP8 pads and Nitrac discs
Hotchkiss 25mm RARB
Competiton Clutch stage 4 clutch + Competiton Clutch lightened flywheel
Quaife LSD in facelift box
16x7 Speedline Turini's + AD08R's, good condition wheels + good tread
Stud conversion
Vibratechnics upper, lower and gearbox engine mounts
Poly FWRB
M7 strut tower brace, cut for adjustment for KWs
Cobra XL seats
Rear seat delete with GP tray
Coolerworx shifter
Scangauge
Stubby ariel
CC scuttles
CC petrol cap
Joey'd facelift xennons
Freshly rebuilt bottom end by 1320, new piston rings, race bearings and arp rod bolts. Not even run yet.
Turbo kit is an Owen Development Garrett GTX 2863R, doesn't get much better than OD.
Turbo oil filter inline to turbo feed.
The cooling system is all custom by Forge Motorsport, custom rad, intercooler and oil cooler.
Large custom barrel inlet, electric water pump.
Grams wideband sensor and gauge
Custom exhaust 3 inch.
1000cc injectors
Specialist Components ECU with switchable maps (includes cabin switches)
HKS SQV4 BOV running recirculating, I find it holds boost much smoother recirculated
Tapped sump for oil return can be included
Innovate ATX oil temp and pressure gauge with oil feed sensor.
That's most of it. I'm sure there's more.
As it is now.
· Premium Member
Isnt the turbo / engine from that, the one that went into Rich's (odwyer) car? If so, I think as part of that deal, a challenge engine went in the other direction... wonder if thats still in the car...
Steve needs to do another big mini project so that I can buy it off him when he's finished :lol: He does good mini builds :thumbup1:
· Premium Member
Discussion Starter · #12 ·
Yes the engine that went out was turbo and AFAIK yes to OD's car. I don't know about the engine that's in it now. It's not slow though :) When I get up to 1320, I'm sure we will find out, unless there's something I can check myself relatively easily?
Haha a 1320 turbo now would be pretty epic too, get onto him!
· Premium Member
Discussion Starter · #14 ·
Good to see you back in MINI mate :thumbup1:
Did you buy it from a guy called Adam? (he was called Boski on here)
Cheers bud, glad to see you're still at it too! :)
No I didn't but it looks rather like that now, bar the FL lights.
· Premium Member
http://www.minitorque.com/forum/f845/vlad-r53-14334/#post243421
I believe this is after the swap where the turbo engine headed in Rich's direction. I doubt it was the subject of another engine swap so I would assume the JCW race engine is still in there... suprised the history youve got on the car doesnt clarify?
· Premium Member
Discussion Starter · #16 ·
Interesting, I would be surprised that it's still in there from the way it goes, but I will have a read of what came with it :thumbup1:
· Bugger
Its got a random stock S engine in it now. Greig sold the race motor to Vhyper, Greig then sold the car as a near stock Cooper S to his mrs.
1 - 20 of 849 Posts
