Back to the Skoda, starting to find the little niggles on it now, interior door lights not working when you open the door or unlock it, they don’t illuminate on the switch either so will have to work that one out
the headlights appear to be stuck in the low down position as if the leveller inside is in position ‘3’, moving it makes no difference, really hard to see at night on unlit roads, I’ve got a feeling that the rear levelling sensor may be broken bearing in mind the car is a car S front rear end damage, hopefully it’s that as it’s a fairly easy fix, a similar thing happened on my blue R53 where the sensor has a broken arm
PDCs not working, rhey beep when you out in in reverse to tell you they are on but don’t actually do anything when approaching an object, again possibly down to the bumper damage, something to look at while I check the sensor
I may get it to my mechanic to put in his diagnostics machine to see exactly what the issues are, or have a trundle to carsorbikes house for him to have a look!
other than that the TDI tuning chip off the mini has been sent off for reprogramming to the Skoda so I should get that back by the end of the week, I’ve got a double din facia on the way to fit the stereo out of the R53 into it and I’ll also get the vibe bass box and amp in too at some point, I’ve got a load of decent vibe speakers spare in the garage that I may swap if they are the same size but I’ve not looked into that yet
not had a chance to do any more dechroming but again something I’ll do when I get the chance
