A good afternoons work today, 1st seat in place
a basic pictorial how to........
First up was removing the runners off the donor seat, 8 T25 bolts per seat
also remove the seatbelt pretensioner for reuse, it’s a T50 to get the tensioner off the bracket below
This needed to be ground off, my grinder is a 5 inch disc type which keep getting caught on the edge of the bracket, a 7 inch type would do the job easier but it wasn’t too bad, I had to hit the ground off rivet with a centre pop to release it from the seat
This is the seat base plate from ‘powerful uk’ on eBay (who also supplied the black front grille) £56 a pair which when you consider I can reuse original parts compared to buying separate sparco sliders and brackets is pretty good value for money and time saving not having to fabricate or adapt bits
the runners, without the tilt mechanism/boden cable reel attached, a single T15 bolt holds that in place and you have to remove the ‘ribbon’ bracket from the front of the slider too, the runners will then bolt to the plate, they are universal with grooves to the front for the sliding bar, I believe earlier ones were ‘handed’ with only one groove
in place (awaiting bolts)
in with the bolts, remembering the pretensioner bracket, now with this put in place as removed the bolt holes dont line up properly, I ended up grinding the inner upright off completely meaning it fitted nicely on top of the plate
next up, attach the seat, the holes in the plate line up perfectly with the sparco holes
M8 x 1.25 20MM long hex bolts
the site will only let me upload 10 pics per post so you will have to wait in suspense while I upload the final few pics!
