Thanks chaps we,'ll sort that , on a side note when we drained the oil from Sc there was plenty of oil in the pulley side but only a few drop came out of water pump side ,we think someone had previously changed the oil as oil in pulley side was fresh and there was a piece of a torx bit broke in the drain plug ( guessing they didn't have correct Allen key and beat a torx into it ) ,i'm thinking they did it without removing sc as Water Pump o ring was well flattened and hoping they didn't do the water pump side and that would explain the lack of oil in that side ,alternatively could the w,p side of sc be leaking oil ? And if so is can we check for it ?
