1 - 2 of 2 Posts
06 R53 Mini Cooper S
If I put the gas pedal to the metal my mini instantly cuts power and backfires like crazy, the coil , coil wires and spark plugs are all new and still have the problem
Any suggestions will be appreciate it, thanks!
Hi,
Do you have the wires all corresponding plugs 1-1 2-2 3-3 4-4. On my old r53 I had a problem with the t map on the front the wires had been pulled at an angle and used to intermittently disconnect causing misfires and loss of power but rarely lasted long enough to throw a check engine light.
Do you have a code reader?
Sent from my SM-G975F using Tapatalk
1 - 2 of 2 Posts
