61 - 80 of 88 Posts
Discussion Starter · #63 ·
Bagged a set of 17x7.5 et38 ATS DTM that will be sent off for refurb then fitted with 225/45/17 R888R. Not everyone's cup of tea but I like them.
Also begun painting up my megane rs calipers
Sent from my LYA-L09 using Tapatalk
Discussion Starter · #64 ·
Wheels been sent for refurb, set of 4 r888r to go on
Discussion Starter · #66 ·
I was going to suggest originally ado8r but no longer available, & the latest s version has mixed reviews
id like to hear from someone who has had both on a mini?
This is why I didn't order them tbh mate as I've heard bad things. I liked the ad08r on the megane as an arrive and drive
Discussion Starter · #67 ·
Come out well I'd say
Discussion Starter · #71 ·
Power steering pump changed and my pro alloy intercooler has returned after being repaired. Amazing customer service from them
Discussion Starter · #72 ·
Also my custom braided lines for the megane brakes from WGMotorparts
Discussion Starter · #73 ·
Well a productive Sunday...serviced, painted and fitted the facelift charger I had, cleaned and painted the Inlet and cooler horn. Just waiting for new belt and should be good to go
Discussion Starter · #74 ·
So realised car is probably due a water pump so ordered new one and whipped charger back off. Then got bored and painted the block and went mad with the gold tape #becauseracecar
Discussion Starter · #75 ·
Today job
Water pump
Injector seals
Refit everything
New belt
Discussion Starter · #76 ·
So car is back together and works...however even after changing the power steering pump after a drive I loose all power steering
Discussion Starter · #77 ·
Literally just waiting on my brackets and I'm good to go
you expecting a problem bleeding it 😂
Reactions: Vaios
you should have two left really, sometimes it's worth a preliminary bleed and check using regular dot4 then run the good stuff through, I don't always but it does save the dearer fluid fwiw
Reactions: Vaios and CSMatt
61 - 80 of 88 Posts
