161 - 180 of 222 Posts
Discussion Starter · #161 ·
Suspension definitely dropped during the little drive last night think I’m happy with the front but the rear will definitely be going up. Will give it a while to settle further.
Love the BRG such an underrated colour.
Looking good.
I agree. Your rear end is too low. Modern FWD cars are run with a little rake (some more than others - my Focus has more than my mini does).
Discussion Starter · #165 ·
Absolutely, will definitely be wanting some slight forward rake. I think the rear keeps dropping as I swapped the springs back to the originals that came with the kit so has been a while since they were compressed.
It's being dropped off at Matt Roach Racing local to me on Wednesday to be with them for the full day Thursday to work their magic on it and get it set up right, camber, toe, pre load, ride height, corner weighting, ARB adjustment.
Figured as I'm using it for track days I may as well get it done properly to realise the full benefits, wouldn't get all of the above done if I was just using for road.
Although with another lockdown looming it's looking like COVID will scupper my Jan & Feb track days at the moment...
Discussion Starter · #166 ·
As feared Snetterton on 31st Jan has been cancelled today. Bit annoying as was a good price and a weekend so meant I didn’t have to take the day off work.
Brands late Feb could also be at risk depending on how the next few weeks go.
As such I’ve cancelled the suspension set up as it’s not essential and in case I get cabin fever and decide to bring forward any handling mods that I had initially planned for after the track season.
Discussion Starter · #168 ·
Snetterton was booked with Opentrack, they’ve cancelled and added a credit to my account.
Brands is with MSVT as got a voucher for Christmas.
RARB inbound, Whiteline has them on sale and are also offering a discount for signing up to their newsletter. I sense some fun with subframe bolts coming on 😎
subframe bolts just use a 16 hex socket and you shouldn't have them burr over, the trailing arm front bracket bolts are the same as the rear frame but if you order new they have changed the style to Torx fyi.
Reactions: Fro-dizzle
Discussion Starter · #172 ·
Got a bit of time on the car today, so got the old ARB off and the whiteline on and the subframe torqued back up.
Not a bad job at all to be honest was expecting a fight to get the old bar out and new one on but it went well.
Removed
Side by side
New one on
The rear is far too low and is running some crazy camber as a result so will raise the coilovers whilst they are off and also shorten the control arms but didn’t have enough time to play with today so will finish over the coming days dependant on work.
Also heard a rumbling from the rear the other day which sounds like a wheel bearing but there is no play so if the raised height and lower camber doesn’t solve it I’ll need to get that sorted likely using R56 bearings.
Discussion Starter · #174 ·
Haha good to hear, seemed like a sensible place to start.
Actually itching to do the weekly shopping run if I can get it back on the ground in time 😂
tyres can sound like a bearing
Discussion Starter · #177 ·
Thanks Sean, couldn’t hear them like this before but I guess there could be extra noise due to the spherical top mounts?
Where did you get the bar from ? ta
Got it from Whiteline/their UK distributor, everything is 10% off plus when I first went on the site it offered me a £20 voucher if I signed up to their newsletter too. 👍🏽
Discussion Starter · #178 ·
All back together, raised the coilover height and also removed some of the camber.
Looking forward to driving it when I go shopping tomorrow. Then will get full set up done once I have sight of next track day which is Brands in Feb at the mo but I imagine COVID restrictions will knock that on the head.
Decided to leave cleaning until another day haha
Whats the quality of the silver project RCA's like @Fro-dizzle ? Any more updates on the Meisters? Your build is very similar suspension wise to what I am planning!
Discussion Starter · #180 ·
Pretty good in my opinion definitely great value when compared to the price of others. Quite a few people on here are using them. If you want any close up pics I have the pair I purchased for the upper arms unfitted in the garage.
Still haven't driven the car much due to lockdown. I did an initial test drive on which the handling was remarkably better, more positive with regards to turn in, and less roll, was taking corners with ease. Also more comfortable than standard suspension, but I'm only running 15 from soft on the front and 9 from soft on the rear.
Still need to have a good drive and push it but seems like a very capable set up. and the above was without the ARB so expecting even further improvement from that.
