Few bits done today, the car was trolling me though so didn’t get as far as I could have.
Got the slave back into its bracket and checked the pedal, feels good, lighter than before but not overly so.
Gear stick goes into all gears nicely.
All wiring has been rerouted to the correct locations and most of it plugged back in except ECU.
Noticed some sheath damage to injector 4’s wiring so need to fix that.
Oil cooler, thermostatand the two hoses near the thermostat are reconnected.
Driveshafts are back in. (Trolling number 1 - Intermediate bearing bracket top bolt was a PITA)
Ball joints and track rod ends are back in the hub.
EVAP, Fuel line and brake booster reconnected.
Made a start on the manifold bolts (Trolling number 2) but it’s not lining up perfectly for some reason spent a lot of time here trying to get them all to play ball but I may need to release the centre plate under the car to give me some movement.
So it’s getting there. whilst the wheels are off I’ll change the front brakes back to road pads and discs. Will also drop the struts slightly to adjust the camber plates to give a bit more negative up front. Think it’s about -1.5 atm so will have a stab at getting it around -2.
Hoping to finish for Sunday so I can take it for a spin but time will be limited over the next few days so we’ll see.
