throw that adjustable in the bin ffs 😂
😂😂 my lil trusty, got a big boy one too. Need to get a spanner set as I have a few sizes missing, that little fellow has got me out of a pickle a couple of times.throw that adjustable in the bin ffs 😂
The pump works as the washers pop out but no spray, think they are blocked but like you say doesn't bother me as nothing worse than cleaning it for those buggers to spray all over the place.Mate this things coming along so nicely 👌
Headlamp washers is probably just the pump mate, when they get run with no fluid in them they end up going pop. I got my mate to change mine out with one from a breakers, air line down a couple of the pipes and they worked perfectly again.
That said....I know you'll get pissed at them splattering your prestine car once they are working![]()
Solid 10ft car hahaThe paint looks fantastic.
1368 same as they list for a 15%.what length belt did they give you?
Thanks, won't that be mega tight on a 13%? Have seen people use them on a 15% and say they are pretty tight?I'd be fitting a 1360
I’m down to tango if it fits.up to you bud, had a few here with kits supplied from there and I've used different belts on all of them fwiw.
