1 - 20 of 20 Posts
New and genuine ATS DTC wheels, 17"x7.5" ET35, 4x100
Color available: glossy black, antrachite, silver, white
Made on specifications, centering direct on wheel (no rings) specific for Mini, 4 holes. Weight 7.5kg
Possibility to request also wheels not painted (now not on stock)
Price for wheels set: 950€ + shipment from Italy
Price for wheels set unpainted: 850€ + shipment from Italy
Price of ATS caps: 32€
More infos in PM
30628955_1990116227697761_7011317524109197312_n.jpg 30656508_1990115757697808_3830302897438982144_n.jpg 30594870_1990115891031128_9052738831635185664_n.jpg 30623655_1990115614364489_7554031331093512192_n.jpg Black_cap.jpg
for clarity when you say unpainted do you mean default silver or no paint at all?
the other wheels you posted, borbet? You have 12? Or they're just other boxes in the pic?
They come in silver, anthracite or black standard colours, you can get them made to order in ral paint codes for extra
so what's the unpainted? actually unpainted? silver very tempting, still a bit high. Also wonder how the weight stands against the Borbet challenge wheels he advertised as well, I like them, same design as my R112's which I'll sell and use them instead perhaps.
Hmm apologies, I was talking R53, I realise they do fit different on R56.
I found ET35 to be arch hungry, even with a decent bit of camber, tyres were wide though.
For a road tyre on a 17' such as a PSS in 205-45 its a perfect offset. If your running huge rubber then your going to need to trim some arch and get the angle grinder out on the rear lip. For a lot of the BBK's you need something like the ATS to clear the front calipers.
Team Dynamics ET35 17x7 205/45 r888r. Rub a dub dub.
I wouldn’t buy et35 again I would rather use spacers and play safe.
That's down to an R888 being 215 - 50 in that size in normal money. I've got some pictures somewhere of the difference between a few.
Discussion Starter #14
Not default silver but unpainted. You can paint the wheels by yourself ;-)
Now only 4x Borbet wheels left, but i can make new order for other set
Discussion Starter #15
ET35 is perfect for std camber, a lower ET needs camber plates to stay into the profile of the car.
P.S. GP2 calipers needs 3/4mm of spacers with ET35, so ET32/ET31
More infos in PM
View attachment 86705 View attachment 86713 View attachment 86721 View attachment 86729 View attachment 86737
Hi Do you still sell these?
JCW N18
I think the wheel have been discontinued in 2020.
That is correct.
ATS motorsport department due to Covid crisishas been closed.
I have contacted them for DTC and some custom work and they told me that unfortunately they cant do anything since factory is closing!
1 - 20 of 20 Posts
