41 - 55 of 55 Posts
Discussion Starter #41
stayed with the Newman cam then?
consider changing the valve springs and caps perhaps, it'll buy you a few hundred rpm....
Yes, CATCAMS was out of stock and i needed it. Think i have choosen a good cam.
Do you need them till 7300/400 RPM?
Discussion Starter #44
I'm running the same ECU in mine. Very pleased with it so far
Do you use this PNP Black version?
How did you get a long with the tuning? Im going to do it with a friend that does his own M2 Competition and started doing others.
Yes PnP. Nick Aristeidopoulos (NickBMW) and Nick English have been helping me
Discussion Starter #46
Car is working with the EMU. Now running in the engine on MILLERS mineral oil and then let the games begin.
Many thanks to Sim0n0 for the assistance since a few days ago, also for the JCM arriving ;)
Still a lot till its even decent to push.
Discussion Starter #47
Guys,
Car is beiing tuned with the EMUBLACK.
I have 17 on the SC and +2 on the crank, ported head,IC GP and Newman PH3/4. Car is making 19-20 psi????
Any idea what can be?
Discussion Starter #51
Dont think so, already had replaced all gaskets and seals, SC maintenance etc. Now did bearings, piston rings, head and cam.
Using GP IC which is up for sale as it cant cope with my IATS where i live.
for how much and in what condition?
did you already have the +2 installed?
so what was the last thing you changed, the head and the cam?
Discussion Starter #55
So car was on 17 + 2, intake, 8ES, Airtec TMIC, stock manifold pre-cat delete, one ball exhaust, 380cc and tune.
Shortly before it stops i did put the GP IC, not that different on boost.
Then the thermostat shit himself and blocked the coolant passage. Main and rod bearing, ARP rod bolts, Pistons rings, timing chain kit etc etc. On this service i put head and PH3/4, BPV spring, 550cc, JCM header and EMUBLACK Ecu.
41 - 55 of 55 Posts
