Hi,
I have recently purchased a 58 plate (UK) N14 engined factory JCW with 109K on the clock. Several "bits" have been done such as new clutch / flywheel 3k miles ago. New thermostat housing, water pump, V pulley, tensioner. New valve stem seals, timing chain, walnut shell decoke on head, braided turbo pipe etc.
Recently it overheated and came to a stop. The coolant tank is pressurised on start up so I would assume the head gasket has gone but also it comes up REALLY quickly with the oil pressure light.
Doing the head gasket is the thick end of £1200 and I still don't know if it will "sort" the lack of oil pressure, so I am leaning towards either:
A. Breaking it for parts to recoup some of the costs so far.
B. Getting a recon engine.
C. Getting this engine rebuilt / reconditioned.
D. Installing a "known" used JCW engine.
So my questions if anyone can / will help me out please?
1. Is it worth having it on my driveway as I part it out (hassle Vs Recoup)
2. Can anyone recommend a company that supply recon engines (personal experience as opposed to hearsay please)
3. As above for rebuilding THIS engine.
4. Does anyone supply known, warrantied N14 engines for the R56 JCW.
I (potentially) appreciate all input and / or insights into the above.
Regards, HD
Regards, HD
