1 - 20 of 25 Posts
So I may as well start a thread on my R53
I bought it of my Friend with a suspected Supercharger Failure a few months back
2003 model in Dark Silver with a few things done
17% Kavs reduction pulley
Kavs upgraded alloy deflection pulley
Some poly bushing done,arms engine mounts
Induction kit
Standard exhaust with one ball mod fitted )previously had a bigger one but changed back to quieter
Plans for the car are get it back working and use it as a daily driver for the next few months
and add a few of the usual mods R56 breaks etc.
sort all the small oil leaks too.
This is my first R53 having had a Mini One with a remap last year and before that having 7 or 8 classic minis
I always like to have a Mini about and think I will keep this one now and just get it sorted and how I like it.
97689
Anyway my Mate/Mechanic started to go at it today to find the fault
Having removed the supercharger all looks good
The water pump isn't exactly free to move as in doesn't spin much
The supercharger had oil in both sides and the teeth on the cogs also look fine
the cones also look good too
The tensioner was bad also and we now have hit a nightmare with that
whoever was at the car before the 2 bolts for the tensioner are broken off so now we need to figure that out
we where going to the take the timing chain cover of to get at the bolts at the back but don't think you can get access on it
so currently getting the engine up as high as possible to see if we can drill them out but don't think this will work either
what started a relatively simple job this morning has turned in to a nightmare ?
Bar the pictures i was sent he has told me all this on the phone so i hope I have explained it correctly
I have a low mileage supercharger here to go on,new water pump,new pulley,new tensioner super charger oil etc. so hopefully these tensioner bolts can be sorted.
I will update further as things progress
(Service Mode)
97690
97691
Oil that came out of old supercharger
97692
snapped bolts
97693
97694
Yep,spot on, thats where we are literally just now
I just ordered a cover/oil pump ebay
and a crank shaft pulley tool
so have to wait until they arrive
tried everything even easy outs and it just broke in the hole so seems like the bolts where seized
I have the exact same pulley tool. Top tip....when I comes to befitting the crank pulley you will find that the original bolt is too short to pull it back on. Use one of the engine mount bolts to pull it on enough then replace it with the original one to finish up.
observe the 'flats' of the pump where the damper fits through, are in line ;O)
I can't say I'd be putting a used oil pump on my car, at least not without cleaning the pressure relief and inspecting and quite probably changing the gears
Thanks for the tip
Yeah I was wondering about the pump
Thanks for letting me know
It cannot be removed from the cover I guess ?
the cover is part of it, you can see the Torx bolts on your pic
Discussion Starter #11
Everything is back together and there was still a noise in it
The Alternator appears to be seized (wont turn freely bye hand )
@CarsOrBikes was correct when he said the noise sounds like it could be more than one item anyway,bang on the money there (y)
On route to get a alternator now
Hopefully will sort it
tensioner bolts snapped off (tensioner shock absorber seized) ,bad crank pulley , bad alternator
If that is it I wonder which one was the cause
Would I be right in thinking that whoever fitted the KAVS 17% crank pulley should have made sure that all the other ancillaries where in good order before doing so
is it advisable to change most of that side if adding a pulley to a 90,000 mile car I wonder
Anyway will update later
fingers crossed
Discussion Starter #12
Alternator i went to get was wrong
Cooper S one is different to Mini One so had to order one from ebay
Will have to wait until arrives now
Wouldn't have thought they would be different
some damage done to the alternator all the same
97849
Discussion Starter #14 (Edited)
Alternator fitted and all back together now and the noise is gone :cool:
We just need to replace the Coolant bottle which is in poor enough condition and all sorted
should be using it as a daily driver from next week
Discussion Starter #15
Did a nice 75 mile drive in the car today after collecting it
Pulls very well and great to be back in a Mini
Brakes are a serious weak point now
so I want to do the r56 brake upgrade to it
Does anyone know will that work for a conversion and if so is it just brake lines i need to get after that.
Discussion Starter #19
Decided to order Used R56 Cooper S callipers and carriers of minitech instead
I think I will order up Brembo discs later and Ferodo DS2500 pads and HEL brake lines
ordered 2 x continental tyres for the rear also
fitted the new coolant bottle
and fitted a new Varta battery
ordered a stubby aerial
Might paint the calipers red and stick the cooper works decals on
Discussion Starter #20
im trying to order Ferodo DS2500
anybody know which pad
for the r56 cooper s caliper that takes the 294mm disc
is it Ferodo part number FCP1561H ?
Just dont want to order the wrong ones
1 - 20 of 25 Posts
