Ok, so like most threads, my resistor was blown. Installed new resistor, jumped the fans and both stages run perfect. hook everything back up and nothing. changed the coolant temp sensor, no change. all the relays check good and there is power at the connector. For some reason, when the a/c pressure sensor is unplugged, the fan runs constantly. my ps fan is removed and the fuse is not blown. a/c has been a pain also. really could use help.
