Black Pro Alloy intercooler in good condition.
The holes where it mounts to the manifold are slightly worn due to a previous owner not using washers.
I used washers and a bit of gasket sealant as is recommended and it sealed fine.
One of the bypass valve threads isn’t great as has been over tightened in the past. Sealed fine with just the two but would recommend re tapping or using nut and bolt.
Both can be seen in the pictures below.
Good condition otherwise, will come with modified stock scoop diverter and rubber strips to aid sealing to the bonnet.
£319 collection preferred from Leigh on Sea, Essex.
May consider post at buyers expense.
